OIL CHANGE TIME
Old Mar 29, 2004 | 06:37 PM
egghead's Avatar
Default OIL CHANGE TIME
i have a 2003 500i auto break in procedure is done
i am changing the oil the manual tell me to remove
the oilfilter plug from the filter mounting boss
and allow the filter to drain
were is that plug?
2003 500i auto 110 miles
Old Mar 29, 2004 | 07:50 PM
DenverCat's Avatar
oilfilter plug
Not sure what that is. I just changed the oil in my 500 TRV weekend before last. I just placed an oil drain pan under the crankcase and removed the oil drain plug. Once the crankcase was drained I just unscrewed the oil filter, set it in my oil drain pan and let it drain there. Doesn't drip much oil when you remove it as long as you let the crankcase drain completely before removing it. If there is some kind of a plug that you can remove to drain the filter before removing it, that's news to me.
Old Mar 30, 2004 | 06:09 PM
Cub's Avatar
Cub
yeah there is a small drain plug right under the oil filter. It is in an awkard place and the only way I fount to remove it was with the wrench in the tool kit. go to www.alpha-sports.com and look in the parts breakdown. It may show you a picture to find it in.
hugemoth
Jul 20, 2020 03:28 AM
toonces
Oct 16, 2019 12:11 PM
Sjrpp
Jul 5, 2015 09:04 PM
yambam13
Jul 4, 2015 01:49 PM
