03 kodiak
Old Mar 29, 2004 | 08:55 PM
kawasaskirules's Avatar
Default 03 kodiak
alright well i'm pretty sure i'm getting gators 26-10-12 the hole way around would this be find and would they fit on the stock rims.??or should i stay with the 25-10-12 also i can hear when i am riding the kodiak it sounds like the front dics breaks are rumbing..
Old Mar 29, 2004 | 09:09 PM
Default 03 kodiak
anyone
Old Mar 29, 2004 | 09:17 PM
paco96's Avatar
Default 03 kodiak
check your brake pads.. and make sure calipers are moving free
Old Mar 30, 2004 | 09:47 AM
Sparky660's Avatar
Default 03 kodiak
For the tires they should fit the stock rim. Go with the larger ones if you need ground clearance but remember you will loose some power going with the larger diameter tire as well as the increased weight of the tires.
Old Mar 30, 2004 | 04:14 PM
Default 03 kodiak
yea thanks guys but the kodiak will still turn the tires in watery mudd right??
Old Mar 30, 2004 | 04:20 PM
FastbansheeandKodiak's Avatar
Default 03 kodiak
The kodiak will turn 26 inch tires easily, even 28 mudzillas arnt a problem.
Old Mar 30, 2004 | 04:38 PM
Default 03 kodiak
yea maybe the 02- and below kodiaks but the 400 03 kodiaks don't have the low gear
Old Mar 30, 2004 | 07:42 PM
Default 03 kodiak
anyone...??and would the 26-10-12 fit on the back and front
Old Mar 30, 2004 | 08:11 PM
Default 03 kodiak
It doesnt matter really i can turn the 28 in high gear and thats all i use, the only time i use low is to tow. And since the new 400 kodiaks gear is in between low and high you wont have any problems. And if you do find it needs more power get a k&n filter and jet up for extra low end with will cost very little.
Old Mar 30, 2004 | 08:18 PM
Default 03 kodiak
thanks FastbansheeandKodiak
