03 kodiak
alright well i'm pretty sure i'm getting gators 26-10-12 the hole way around would this be find and would they fit on the stock rims.??or should i stay with the 25-10-12 also i can hear when i am riding the kodiak it sounds like the front dics breaks are rumbing..
For the tires they should fit the stock rim. Go with the larger ones if you need ground clearance but remember you will loose some power going with the larger diameter tire as well as the increased weight of the tires.
It doesnt matter really i can turn the 28 in high gear and thats all i use, the only time i use low is to tow. And since the new 400 kodiaks gear is in between low and high you wont have any problems. And if you do find it needs more power get a k&n filter and jet up for extra low end with will cost very little.
