crashed my prairie
Old Apr 1, 2004 | 12:20 PM
gIMpSTa's Avatar
Default crashed my prairie
Hello
This past weekend I crashed my 2003 kawasaki prairie 360. I was going about 25mph and got pulled off trail by some slush/water and caught a tree with my front left tire. At first I thought I busted a cv shaft so when i jumped off and looked I was quite suprised to see what had actually happened. Let me see if I can even explain what it is I broke. On the tire side of the cv shaft (not the xfer case side) there is a cast metal peice that the tire and everything attaches to. The suspension attaches to the top, the tire hub is held on here, and the cv shaft passes through it. This entire metal cast piece broke into two pieces, so now my tire is only attached by the cv shaft, and the lower joint of the bottom half of that casted metal piece. The strut is just freely moving around as the top half of the metal cast is still attached to it, but broken free from the rest.
Has anyone else seen this? What is the best thing for me to do? Contact kawi and get a replacement part i assume? What would I call the piece I need to replace?
Thanks in advance for any words of wizdom.
Kevin
27" Titan 589 m/t
Clutch spring kit
White brothers exhaust
Old Apr 1, 2004 | 12:33 PM
alltoys's Avatar
Have you tried the warranty side of your dealer that is my first thought. If past warranty then you are hooped buy a new one and istall yourself or take to your dealer. Could be a defect in the part I haven't heard of anyone else having this problem.
Old Apr 1, 2004 | 01:16 PM
gIMpSTa's Avatar
It is definately past warranty. I probably should have bought the extended warranty, but i've had it for going on 2 years now and the warranty I had was for 6 mos. I plan on doing the work my self, i've done a lot of work on mine and my buddies prairies and it doesn't seem to be do bad of a job. I was just curious if anyone else has seen that happen. Seems like kind of an odd thing to break. I've busted a cv shaft on the other side and it took a much harder hit then this crash.
27" Titan 589 m/t
Clutch spring kit
Old Apr 1, 2004 | 02:21 PM
Prairiewrench's Avatar
Yep, another guy was riding one of our 02 Prairie 650's and hit a tree and did the very same thing,,, ripped it right off! That was a few years ago now!
Old Apr 1, 2004 | 02:32 PM
gIMpSTa's Avatar
Prairiewrench:
Do you remember what it ended up costing ya to fix it?
Old Apr 1, 2004 | 03:24 PM
TriumphDude's Avatar
A guy on ebay was selling parts last week and he had a steering knuckle. I bought some stuff from him , but didn't want the knuckle. I can give you his email address, if you pm me.
Old Apr 1, 2004 | 03:59 PM
gIMpSTa's Avatar
The part is $123.90 from my dealer. Not as bad as it could be I guess. I will keep looking online tho.
Old Apr 1, 2004 | 05:17 PM
Kawi650's Avatar
I feel warrent wouldn't cover this. I think the price is good... Chalk it to a bad weekend and replace the part. You might find that your steering might need a little attention as well... You can not fully tell until it's back together. Hopfully you didn't bend your strut or mounts.
Old Apr 1, 2004 | 05:18 PM
Nightryder888's Avatar
might want to try ronayers.com
Old Apr 1, 2004 | 05:19 PM
fidge1's Avatar
A kid I ride with rolled his 03 p650 and bent stem,bars,plastics cracked, console broke and it costed him over 800 bucks out the door.
