Prairie 360 running a little sick. help
Old Apr 2, 2004 | 01:44 PM
alwaysride's Avatar
Default Prairie 360 running a little sick. help
My 04 360 has been running perfect untill know. Last sunday when i went riding, it seemed to be running hotter than it usally does. The fan was always on and i could feel the heat through my jeans. Also, when i would turn it off or let it idal for a little bit it would bog down when i would take off. Somtimes it would do this two or three times befor it would run perfect except for the heat problem. It is still under warrenty and im going to take it in this week but i just wanted to ask you guys. Could it be a jetting problem. THat is what i think but im not sure. Thanks for the help. And dont forget that kawasaki rules!
Old Apr 2, 2004 | 02:41 PM
MikeRhyne's Avatar
I'd check the usuall stuff starting with the oil (level and quality) then look at the air filter and plug. Also look at the oil cooler to see if its clean as if its not it won't work real well and cause the heat problem. I doubt its jetting unless you were riding at a different altitude than normal or it finally fouled your plug. If that all looks good take it to the dealer since its under warrenty and t might be a timing issue.
Ours had bogging problems at one point and it was bad gas but there wasn't a heat problem with that.
kwackermann
Jul 6, 2015 11:01 AM
kwackermann
Jun 24, 2015 10:18 AM
bodatiouskid
May 27, 2015 08:33 AM
JRM
Oct 9, 2000 08:35 PM
