Yamaha badger yfm80 clutch removal
Old Apr 5, 2004 | 03:55 PM
micscottj's Avatar
Default Yamaha badger yfm80 clutch removal
i have a 1987 yamaha badger yfm80. i am trying to install a new shift shaft, but i must remove the clutch assembly. I don't know how the clutch assemble comes off. Is it pressed on or what? Can anyone tell me how to remove this?
Old Apr 6, 2004 | 10:14 AM
asfasasu3's Avatar
Boy o boy testing my memory. I changed the clutch in ours some time ago....... it is not pressed on to get to the shaft do you have to take the clutch off or the adjuster off? The clutch is on the opp side of the adjuster, I'm not really sure how the adjuster is made in there. A good place to look for info, find drawings/ microphilm from places like Honda of troy, I think rocky mountain has these also. The clutch is the same (or should be) for the newer Badgers. Try http://216.37.204.205/Yamaha_OEM/Yam...pe=13&A=3&B=16 and see if this helps. They should also show the shift shaft in there somewhere.
Goodluck!!
Old May 4, 2004 | 10:44 PM
Dragginbutt's Avatar
Is old enough to know better, but too young to stop.
Yamaha has a online parts catalog right on their web page.. if you can't get the pics for the badger, try the raptor 80, the only difference is the body panels...
Ean
Dec 19, 2022 08:48 AM
Captjay
Jul 23, 2015 12:33 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
200es
Jul 10, 2015 09:09 AM
Jul 7, 2015 11:00 PM
