help please read this
Old Apr 6, 2004 | 08:59 PM
iwannabfast's Avatar
Default help please read this
when my 95 scrammy warms up it idles really high i dont know what to do i tried to adjust the cable on the bars but that didnt help any ideas
Old Apr 6, 2004 | 09:00 PM
DGScrambler400's Avatar
try adjusting your idle screw on the carb.
Old Apr 6, 2004 | 09:08 PM
is that the spring screw or the one thats hard to get to?
Old Apr 6, 2004 | 09:11 PM
See if this helps Parts Land - 95 Scrammy carb
Old Apr 6, 2004 | 09:12 PM
WFOPredator's Avatar
It's the larger one, with a philips head in it. Yes, it's spring loaded. You can either do it with a screwdriver (long one) or by hand with the airbox removed. If that doesn't help, you may have an air leak somewhere around the jug. My 95 broke the front tabs off where it mounts to the 'block' which caused air to get in, and idle very high.
Old Apr 6, 2004 | 09:30 PM
correct wfo thanks for your help i tightened the carb mount clamp against the engine and it idles fine thanks for your help
ultangler
Nov 30, 2024 01:35 AM
EIF
Apr 20, 2017 07:15 PM
2many2ride
Sep 27, 2015 04:35 AM
kbazzy
Sep 26, 2015 11:26 AM
