oil in air box from vent ??
Old Apr 8, 2004 | 12:55 AM
Indianbullet's Avatar
Default oil in air box from vent ??
just curious i was at the dunes and noticed i had some oil in my air box comming from the crankcase vent that vents back into the air tube this seems like a little un nessessary smog intentions any ideas if i can get away with putting a little K&N vent filter on it or what ??? i was riding it hard so dont know if it was getting in the vent from hitting some sharp angles or what ??? any clues guys ???
also when i went to unload my quad from the trailor the dam little red idiot light came on and stayed on then was doing the dimly lit thing just wondering if any of you are using manual guages if so are they just auto type or what ??? the light kinda conserned me but i had remembered reading post's on on them screwing up and my fan was working fine had plenty of oil in it ect but would love some input from you all on this ????
thanks guys
Old Apr 8, 2004 | 11:09 AM
SANDMAN430's Avatar
the red light is also water temp.
Old Apr 8, 2004 | 02:59 PM
yes im aware that it also reads coolent temp but it actually never got that hot and when it did the fan was running as normal any ideas on guages Sandman ?? how about the oil in the air box ?? any thoughts
Thanks SDee..
Old Apr 8, 2004 | 03:57 PM
ANNIHILATER's Avatar
No Mercy Racing! Got NOS?
Indianbullet- Your red light may be going bad, I actually replaced one last night( It went dim and then out completely). I thought it was the connectors but it wasnt.
Another reason the light would start to flash and dim, is if your oil res filter is plugged up, the oil pressure would be low and light will sputter on and dim.
I run an ESR in line water temp guage, and it is "pretty" acurate compared to a temp gun reading on the cylinder.
The exess oil in the air box is probably blow-by, I lose a little oil out of my crank case breather vent hose ever time I ride.
Old Apr 8, 2004 | 04:46 PM
where might i find that esr water temp guage ?? would rock mt or denis kirk have them you think ?? as for the oil screen being pluged the bike is less than a yr old only had to change the oil once and i did pull the filter screen then and it was cherry
i just despise idiot lights and would like to put little mini guages on it for oil and coolent temp thanks again ...be nice to do away with the blow by in the dam air box as well kind of a mess
Old Apr 8, 2004 | 05:40 PM
BabyMoose's Avatar
I have noticed some gas coming into my air box, what could be causing this???
Thanks!!!
ReconBayou
Oct 31, 2022 05:37 PM
SDR-II
Sep 29, 2015 01:06 AM
bvolks
Sep 13, 2015 12:57 PM
KSJOHN
Aug 30, 2015 08:15 AM
Captjay
Jul 23, 2015 12:33 PM
