sand tires
Old Apr 9, 2004 | 02:18 PM
thebigshow's Avatar
Default sand tires
im getting ready to order some sand tires. i have narrowed it down to three i like....which one would u go with for drag racing purposes?...............extremes...edge......or haulers???????and what size?
Old Apr 9, 2004 | 02:37 PM
Freakneh's Avatar
Default sand tires
I've used Haulers, and Edges. I'd suggest the Haulers, because you have the power to turn them. Haulers have awsome straight line performance. That's why all the big dogs run them. As far as a size, I've only ever ran 20x10x10 8 paddles. Considering your bikes got some power, you'd probably be safe with a 9, maybe even a 10 paddle tire. I'd suggest a 9 paddle, then play with air pressure to get what your looking for. If you were on a less powerful bike, say a stock 400ex, then the Edge would be a good all round tire. I don't know if the Extremes are worth the extra $ or not. The regular Haulers seem to take a beating from the super trick Banshees just fine.
Justin
Old Apr 9, 2004 | 02:39 PM
biggerisbetter's Avatar
Default sand tires
Have you hubs drilled tapped out with the Yamaha, or Honda bolt hole pattern. Then go get you some 22/11/8 --8 paddle tripple buffs from JimSAND TOYs in Waynoka OK. these are THE BEST for drag racing.
Bigger.
Old Apr 9, 2004 | 03:08 PM
SoonerDuner's Avatar
Default sand tires
Jim's Sand Toys is awesome. He's really reasonable on his prices. Also, he sometimes has some great deals on some barely used rubber.
Ooooo, that last line didn't sound right...........
Old Apr 9, 2004 | 08:40 PM
BillDS650's Avatar
Default sand tires
With you engine go with 22X11X? extremes 8 paddles
Old Apr 9, 2004 | 08:50 PM
Slowride's Avatar
Default sand tires
Anybody know the weight of the 22/11/8 --8 paddle tripple buff rim/tire combo?
jbt
Old Apr 9, 2004 | 09:03 PM
thebigshow's Avatar
Default sand tires
whats the major difference in the triple buffs and the xtremes?
Old Apr 9, 2004 | 09:26 PM
BillDS650's Avatar
Default sand tires
triple buffs they all so remove most of the ruber on the side wall very light and get a lot of flats. The Extreme is 1/8 thicker to take on the weight and HP of large ATV's
Old Apr 9, 2004 | 10:25 PM
SANDMAN430's Avatar
Default sand tires
well if you are into pure drag racing the triple buff probably are the way to go. most of us big bore guys out here have found for a good hill shooting plus riding tire we run the 22" 10paddle tire it does slow the flat speeds a little but we have lots of hills to play on so the 10 is handy, the 12 was to much, it was quicker out of the hole but slowed quickly. but these are all around tires pretty good at the race, pretty good at just riding.
Old Apr 10, 2004 | 12:45 PM
Default sand tires
Has anyone ever tried rubbing Vaseline all over thier paddles before racing?
I don't think that it would serve any purpose, I was just wondering if anyone had tried it...
