2 aftermarket carb related questions- banshee
Old Apr 9, 2004 | 10:07 PM
imported_juggalo's Avatar
Default 2 aftermarket carb related questions- banshee
my friend is building a 520 stroker banshee and looking for some carbs. he wants kehin air strykers but doesn't know what size to get. his builder is saying dual 35mm's but that sounds kinda small to me, so i thought i'd get a second opinion on that.
also hes thinking about the single carb set up. what size carb is usually used with this set up? what size carb should be used with this set up for a 520 stroker? the builder is saying 29 or 40mm air stryker but once again that sounds waaay too small. don't the 250r guys run 39's usually on their machines? youd think you'd want somethin way bigger for over double the displacement.
Old Apr 10, 2004 | 06:31 PM
bump...somebody out there has to have some advice
Old Apr 10, 2004 | 07:01 PM
ALIENraptor's Avatar
Dual 35mms sounds about right, remember each cylinder is only 260cc's x2
Old Apr 10, 2004 | 07:44 PM
Imback's Avatar
You gotta be kidding me...Yeah 35mm will do ok although 38mm would be better but a 2:1 set up on a 520 stroker come on!!!!!!!!!!!!!!!!!!
You guys sound like a bunch of clowns for even considering putting a 2:1 carb set up on a 520cc Banshee engine!!!!
No wonder why i read all this crap about built Banshees getting beat by piped 450s and Rappys!!!!!!!!!!!
Old Apr 10, 2004 | 10:17 PM
bad350twin's Avatar
a friend of mine has a 520 and he runs 39mm mikunis!
Old Apr 11, 2004 | 10:56 PM
i know i have been trying to steer him away from the single carb set up but he just wants to be able to tune it easier. he'll most likely get the dual set up tho. so 38 or 39mm twin set up is the way to go then?
Cole Hadden
Jun 15, 2025 09:05 AM
toonces
Jul 16, 2015 03:19 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
