ReconTireSize
Old Jul 20, 2000 | 06:27 PM
pyromaniac442's Avatar
What is the biggest size tire that will fit on a stock Honda Recon with out a lift on the back?Will 25 inch tires fit?I found some that will fit on 9 inch rims,I just want to know the biggest size tire that will fit on a stock recon is.THanks.
Old Jul 21, 2000 | 12:22 PM
snowshark's Avatar
25" tires won't fit unless you put a lift kit on. I put my 24" Rancher tires on the Recon. They fit but the tire would rub.
The 23" tires will fit, however there are not many tire manufacturers that make a 23x10x10 tire! Titan 489 do have a size that will fit.
Old Jul 21, 2000 | 12:27 PM
covert's Avatar
Hey snowshark... how many pounds of airpressure do you put in your recon if you are riding bumpy trails? My hubby and I differ greatly in this, he says 4 1/2 and I say 3 or less for handling. What do you think? This would settle this argument once and for all.
Old Jul 21, 2000 | 03:34 PM
supertraprecon's Avatar
even 25" tires if they are a agresive wide tire (vamps or something) will BOG the thing WAAAAAAAAy down even my wider more agresive 22" TSL's boged it down i still suggest getting 22x12.5x9 TSL's
Old Jul 21, 2000 | 03:36 PM
snowshark's Avatar
Covert,
Initially we ran 3 pounds in all 3 of our quads. Then I went up to 6 pounds, but that was too much. I kept letting air out until it felt right. The Rancher & Recon both have 5 pounds & my kids Eton he is running 4 pounds.....
At three pounds I was worried about knocking the tire off its bead because of the number of stumps just off the trails.
Hope this helps..........
Old Jul 22, 2000 | 06:24 PM
Hondapride's Avatar
Hey Snowshark GBC Mud sharks come in 23" size
Old Jul 22, 2000 | 06:28 PM
Hondapride's Avatar
Yeah I normally run about 4.5 to 5.5 lb of pressure in my tires.
1998 Honda Recon
Supertrapp Ids2,K&N,outerwear,red shockwears,sur tracks on itp and stock fronts on itp
Old Jul 23, 2000 | 03:32 PM
snowshark's Avatar
HondaPride,
The 23" mud sharks are only 8" wide. Are you willing to give up 2" of traction on each wheel for an additional 1/2" of ground clearance?
Old Jul 23, 2000 | 04:56 PM
i bet the 22x12.5x9 tsl's mud better than the 23x8 mudsharks,,,,,,
i think those or mudmachines are the best bet for recon owners right now,,,,, i want some 24" oultaws o well i heard some were there comeing out with 24" mudbugs, but i think they were 9" wide or something
Old Jul 23, 2000 | 11:46 PM
Hey,where can I get the 22x12x9 TSL's?
