How can you guys ride with a lowering kit?
This past winter I bought a CFM front lowering kit and I flipped over thr rear linkage.
Guys I hate it !
On the drag strip its great but on the whoops my bottom hit and scratch everywhere.
Its not that i'm heavy, I weight about 140lbs but damn I get shaked .
Guys I hate it !
Originally posted by: trx250Rob
IF you want to do it right you have to get ZPS.
I love my lowering kit. On the steep climbs around here, they are a life saver. You won't climb half the bad hills around here without a lowering kit.
You could get them from AXIS, PEP, Elka or TCS. Do a search and you will find them.
The fronts start at about $500 for Elka SSD (their name for ZPS) and go up to $1200 for AXIS.
For the rear, most manufacterers could convert your stock rear for about $300-350. A brand new rear will go for about $800-900.
The difference isn't only that you could raise and lower the quad, the valving is way superior to stock. Also even though the quad sits lower you have more travel and they resist bottoming out much better than stock.
Take a look at my pics to see what they look like, in those pics you could see that when you sit on them the quad is pretty low, but in the air they fully extend. In those pics I had them about half way down, I could drop it another 2 inches or raise it another inch and a half.
