i want to cut my raptor fender how do i do this?
Old Apr 11, 2004 | 10:01 PM
kawasaki88man's Avatar
Default i want to cut my raptor fender how do i do this?
anyone i have no clue how to do this like where do u cut them to make them look awsome?
and then wat do u use to make the edges smooth? if i use sandpaper that would scratch the platic.
and another question:
my chain keeps snapping im going to change the chain and sprockets could it be cuz i put a 12 tooth front sprocket on without changing the chain and back sprocket? and the front is chewing the heck out of the chain?
thanks for the advise
Old Apr 11, 2004 | 10:14 PM
AnimalMother85's Avatar
use an airsaw if you have one, or a small hack-saw. Measure points on them, then connect the points with masking tape. this way, they'll be semetricle. you can use 320 grit sand paper, then i would go from that to a wet 600, then maybe a wet 1000 to make them look smooth. Be creative with em, they may come out awesome, or they may look like @$$.
Your chain is probably to tight.
Old Apr 11, 2004 | 10:16 PM
sixsixT's Avatar
If your chain was old and near being wore out a 12 tooth would not be a good idea.
For cutting the plastic I use a jig saw with a fine blade. Use some masking tape to lay it out the way you think it looks good and to balance each side then use the tape for a guide. Use some 180 grit sand paper to clean up the edge.
Old Apr 11, 2004 | 10:22 PM
i kno the chain wasnt to tight cuz i had the tensioner all the way in and the chain still had like 2 inch to 3 inches of slack. but it was old to it was still stock from 02
Old Apr 11, 2004 | 11:13 PM
can someone post picture or something that i can see cut fender on a raptor
Old Apr 12, 2004 | 12:13 AM
injun's Avatar
kawasaki88man how do you like that alba pipe and jet kit? iam thinking about buying one my self. Hows the power, or the noise, and does it sound good.
About your plastics , my friends and i have always cut them with jigsaws or sawzall. just be carefull then smooth it out with some sanding.
Old Apr 12, 2004 | 12:29 AM
sixsixT's Avatar
I'm not sure if a link to imagestation will work but I'll try Pic here
Nope. Try this
Old Apr 12, 2004 | 12:40 AM
INSeaRChOFDUNez's Avatar
is that your raptor sixsixt?
psychotic400ex's Avatar
I found the best way is to take off your fenders, take a Dry-Erase markers, draw on your fenders and pick a line you like, and cut it with a dremel, then take Snowmobile windshield trim, and put around the edges. Looks good.
Old Apr 12, 2004 | 12:41 AM
i forgot to mention, it's easier to follow the "crease" if you cut from the back side of the fender.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
