carb?
hi!
i just recently bougth a ds 650 and it was having a carb problem so i took it apart and cleaned it now it's ok but when i shake the bike there is a few drops coming out of the overflow. what do you think it is?
thanks
thanks
so how do i adjust them? what is the height and where do i mesure this? cause i played with the little plate, but i put it at it'S stock place, but maybe it is wrong...
so explain me how do i adjust the floats, and which tools do i need??
Here is what I did to solve the same problem that you have when I had my stock carb.
1 - Get a clear tube and place it on your drain outlet.
2 - hold the clear tube straight up next to the carb
3 - turn on the fuel to the carb and open the drain screw
4 - This shows WHERE The fuel is sitting in the bowl.
Remove the bowl, and remove the screw that holds the floats. do not loose any parts, I would to it on a table. Ensure you look at how the floats connect to the plunger. Its really easy but just so YOU know. Then bend the tap towards the TOP of the carb to lower the fuel level in the bowl only move it with your finger and just push it gently, it might not appear to move but it probably did. Then retest your tube view.
I forget what specs are but just get it so it does not overflow when you shake the bike. If you put it to low then you might starve the carb for fuel under load. I BELIEVE it is like 1/8 inch below the top of the bowl. I dont recall. Its been a while since I had a stock carb.
ok it works great now i didn't adjust the floats with a ruler i just did it with my common sense lolll
but now it works friggin great
and it's friggin fast[img]i/expressions/face-icon-small-shocked.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img]
yeah you convincedme to check this out[img]i/expressions/face-icon-small-wink.gif[/img]
thank you! but there is still a few drops falling but i need to shake the bike more
i think i'll adjust them more
GregM
Mar 6, 2018 06:53 AM
