The old girl isnt running right
Old Apr 13, 2004 | 12:01 AM
maddog56's Avatar
Default The old girl isnt running right
My atc185 is running pretty sluggish. When you hit the gas it likes to bog. Choke is off, Plenty of gas and its good gas too. I was thinking water in the carb or something similar. Any suggestions?
Old Apr 13, 2004 | 12:17 AM
UltimateAussie's Avatar
Are you positive that the choke is all the way off. Mine did the same thing and it ended up being that the choke cable was seized up. all it took was some WD 40 down the cable and it worked pefect. hope it is something small. good luck
Old Apr 13, 2004 | 04:13 AM
maddog56's Avatar
It worked fine since I got it. Went for a ride and it started doing it on the trail after a while. There were plenty of puddles so I'm thinking its a water thing. Choke is a 3 position lever on the carb itself, no cable.
Old Apr 13, 2004 | 12:45 PM
ThrashAndCrash's Avatar
loosen the carb drain in a clean dish.......you will be able to see real quick if there is water in it. if there is then just run a little alcohol (heat). Maybe look for your intake bolts working loose.
Old Apr 13, 2004 | 05:29 PM
dragracer789's Avatar
Check your compression. make sure no gaskets are leaking.
Old Apr 13, 2004 | 09:04 PM
killerKXF's Avatar
make sure there is no water in the air box
Old Apr 14, 2004 | 09:20 AM
dzzy's Avatar
Could be main jet obstructed. If it's got the gas cap with the on\off vent in it, once in a while they go bad and won't allow the tank to flow enough fuel. Pull the fuel line off the tank and put a ratio rite cup or something under the tap, turn on and let it fill up. If it quits flowing or slows down, pop the cap off and see if it resumes flow. Also a good time to check for poo in your gas.
hugemoth
Jul 20, 2020 03:28 AM
Frisky2050
Apr 9, 2020 11:19 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
kwackermann
Jun 24, 2015 10:18 AM
Smokinthebear
May 7, 2000 08:01 PM
