Air Screw on z250
Old Apr 13, 2004 | 09:00 PM
z250freak's Avatar
Default Air Screw on z250
Does any one know where the air screw is on the z250. Mine is always backfiring when Im decelerating so I wanted to know if this would fix it to adjust the air screw.
Old Apr 13, 2004 | 10:47 PM
SuzukiZ250Kid's Avatar
I don't know if that will solve your problem, but I do know its a pain in the butt to get to. I think you will have to remove your carb. to get to it because it is on the underside of it.
Old Apr 14, 2004 | 07:55 PM
hondabuster's Avatar
carb
Its #27 on this picture. There may be a cover over it, that will have to come off.
Usually, if the screw is on the engine side of the carb, it controls mixture and is called a mixture screw. If its on the air cleaner side of the carb, then it controls air, and then its called a air screw. And youre right, if you go a bit richer, the backfire will stop.
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Beeline08
Nov 11, 2016 04:00 PM
Oct 10, 2015 10:20 AM
Jackg17
Sep 26, 2015 09:30 PM
