KFX700 OIL FILTER
Old Apr 14, 2004 | 02:43 PM
Scottyjay's Avatar
Default KFX700 OIL FILTER
Heres a new one, for me anyway. Just finished my first oil change. Replaced oil ( kawachem) and filter. Fired it up and everything was ok, for the moment. The oil light then came on. I checked the oil level, it was fine. Called my local Kawasaki and ran it over for a oil pressure test. It tested great ( 75 to 90 psi). He then noticed my oil filter was not OEM. I had bought a Napa gold because my dealer was out at that time. He said the OEM filter had internal baffles that actually created back pressure. ( I guess the oil sender is at the end of the oil gallies instead of the front) The Napa filter was giving the oil sensor false readings. I switched back to the Kawasaki filter and no more problems. I know a lot manufactuers make replacement filters and I haven't heard of anyone else having problems. Has anyone heard of this? Anyway just a little info, might help someone someday.
Old Apr 14, 2004 | 08:02 PM
Budwsr's Avatar
The oil filter part# cross over is as followsFram P# PH6017A ( kawy replacement)Fram P# 7371 (auto conversion)Purolator P# PL14620 (auto conversion) *Recommended*Note: The Purolator filter is significantly larger than both the stock Kawy filter and any other auto type oil filter that I have found. The extra length of the filter will allow you to add about 4-6 ounces of X-tra oil....a good thing....highly recommend using it.The auto conversion info is as follows: The V-Force uses the same oil filter for / as the......1994 Mazda MX3 V-6 engineUsing this conversion you can use any brand oil filter, and you can also pick them up at any Wal-Mart or Auto Zone type outlets.
I used the Fram filter works great cost me 3.99 at Wal-mart versus 13 bucks at the dealer
Old Apr 15, 2004 | 12:49 PM
Scottyjay's Avatar
Thanks for the help!!!
Old Apr 18, 2004 | 02:55 PM
BigRich's Avatar
Thanks for the oil filter tip. I will try it on my next oil change. Have you seen anyone trying to run a turbo yet. I am looking into it now. If it works, I will post pics when I get it tuned out.
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
