1983 185s
Old Apr 14, 2004 | 11:44 PM
HookShow's Avatar
Default 1983 185s
I recently purchased a runnig 185s for 50 bucks everything is there except for an exhaust. I dont know how long it was ridden with out an exhaust or back pressure and i heard if a 4 stroke doesnt have back pressure it will damage the valves or blow up the engine is this true? any suggestions on an exhaust system or just a quick fix?
Old Apr 15, 2004 | 12:40 AM
KNOWSALOT's Avatar
The Facility
Default 1983 185s
It doesn't even have a header pipe?
True, an open exhaust will burn the exhaust valve and eventually warp or even break in some instances.
As far as finding one, check with your local ATV salvage yard if you have one. If not, I see them on e-bay from time to time and they are very affordable there.
If you still don't find one, you can get an entire obra steel exhaust for it in the $100 range. They are louder than stock, but will not cause any engine damage.
Running an engine without a pipe isn't a big deal until you get the engine at operating temprature. The pipe acts as a conductor and actually helps absorb most of the heat from the cylinder head.
Don't run that thing until you have at least found a header pipe.
Old Apr 15, 2004 | 01:28 AM
atc110rider's Avatar
Default 1983 185s
hey iv ran my trike with out exaust for weeks and it never wreaked nothin
Old Apr 15, 2004 | 04:22 AM
ThrashAndCrash's Avatar
Default 1983 185s
You got lucky on that one then, because Knowsalot is dead correct on this one!
Zachary Carter
Aug 31, 2015 04:17 AM
superdizzyboi
ATC 3-Wheelers
Aug 30, 2015 07:22 PM
Backwoods_badass
Aug 30, 2015 06:59 AM
Dammar
Aug 26, 2015 07:12 PM
CRamshaw777
Jul 18, 2015 05:46 PM
