z400 Jetting/cdi box ?
Old Apr 16, 2004 | 01:29 PM
flyboyz's Avatar
Default Jetting/cdi box
Hey everyone just need a little help with my jetting on my 03 Z400 I just got a full exhaust by bill's pipes and i am getting a k&n filter and was just wondering what size jets i should put in ? and i was thinking of a cdi box and what you all think of them if you have used them, and is it worth it ?they give 1000 rpm more so would i have to jet it different for that to ? thanks
Old Apr 23, 2004 | 12:59 PM
flyboyz's Avatar
Default z400 Jetting/cdi box ?
does any one have an idea?
Old Apr 23, 2004 | 05:49 PM
bvstone's Avatar
Start with 25 pilot, 3 turns out, Alba needle at the 4th clip from the top, and a 155 mikuni (NOT dynojet) main. Should be close to perfect, possibly a tad rich.
Old Apr 23, 2004 | 07:03 PM
13inc's Avatar
I would buy the DYNOJET kit stage 1 & 2. The instructions give different setups for whatever you have done to your machine or at whatever altitude.........
Old Apr 23, 2004 | 07:29 PM
bulldogz400's Avatar
Don't waste your time with a Dynojet kit...I did, and ended up not being worth the $$$ besides the needle. BVSTONES jetting specs look right on.
13inc...nice bike by the way
Old Apr 23, 2004 | 08:30 PM
KFXCarnage's Avatar
Thats sounds like some complicated jetting.I'm glad all I had to do was change out my main jet.HMF recamended a 175 and its perfect.
Old Apr 23, 2004 | 08:46 PM
bvstone's Avatar
It's not complicated at all. 175 is WAY too fat for the main.
Old Apr 23, 2004 | 10:09 PM
Christoblue's Avatar
I don't know what elevation you guys are at but a 155 sounds lean to me. I live in southern AZ around 2900ft for elevation and I have done the prodesign pro-flow filter with no lid and I,m running a 150 mj. When I det a pipe later this year I not sure what mj I'll have to use but I imagine it will be a 160 or 165.
Old Apr 23, 2004 | 10:23 PM
bvstone's Avatar
No, most people run a way fatter main than they need... on the Z, you should never need to go over 160.. Even with my 42mm carb I'm running a 155 and I gather it's a little fat.
If you were running too lean, you'd know before causing damage. People are still paranoid about running too lean from the 2 stroke days.
Old Apr 23, 2004 | 11:29 PM
BV's right again. Many people think that the higher main jet you slap in the more power you will get...which is all wrong. I also think that a 175 is too large for a pipe only...try going down a couple sizes and see what that does for ya, and if it doesnt work...than go back to the old. Can't hurt to try!
