how do i make a warrior faster
well, the quickest way to make your warrior faster is...unscrew the gas cap, roll your warrior forward, roll a banshee where your warrior was, put your gas cap back on the new machine, if you wish real hard, you may be able to get away with calling it your warrior.
I did say offroad! I think I hit better top speeds offroad with a 12T sprocket! With my mods I can smoke a buddies warrior with stock gearing and a FMF exhaust offroad lowend or topend. I love it! Rejetting is in the Carb. supplies more gas, done when you mod the exhaust or airbox!
I forgot, Im assuming you have 20inch aftermarket tires. With 22s though, a 12 is close to what the stock is with 20s.
Originally posted by: bagz
when im doing donuts its real easy for me to flip even though i lean to the inside of the turn .. is it supposed to be that easy?
If you're on dirt you need to lean more.
Heres one really easy handling mod. Flip your rear tires around to make it a few inches wider. It helps, only downside is you have to air em up from the inside side, but its not much inconvienence.
