how do i make a warrior faster
Old Apr 17, 2004 | 12:33 AM
bagz's Avatar
Default how do i make a warrior faster
hi what can i put on my 1999 warrior to make it go faster without spending alot of money?
Old Apr 17, 2004 | 12:49 AM
AnimalMother85's Avatar
well, the quickest way to make your warrior faster is...unscrew the gas cap, roll your warrior forward, roll a banshee where your warrior was, put your gas cap back on the new machine, if you wish real hard, you may be able to get away with calling it your warrior.
Old Apr 17, 2004 | 12:50 AM
BadDay350's Avatar
Buy the Alba kit (pipe, K&N, jets and torque stuffer) for less than $300. Other than that put a 12 tooth sprocket on the front if you want more lowend torque offroad.
Old Apr 17, 2004 | 12:52 AM
bagz's Avatar
lif i put the 12 tooth sprocket on and it increases low end is that quick in the begining or a higher top speed? ,......... also i wanna no what it means to rejet
Old Apr 17, 2004 | 12:56 AM
JakalWarrior's Avatar
You get a useless first gear and a lower top speed. You also shift more. Great huh?
Old Apr 17, 2004 | 01:06 AM
BadDay350's Avatar
I did say offroad! I think I hit better top speeds offroad with a 12T sprocket! With my mods I can smoke a buddies warrior with stock gearing and a FMF exhaust offroad lowend or topend. I love it! Rejetting is in the Carb. supplies more gas, done when you mod the exhaust or airbox!
Old Apr 17, 2004 | 01:10 AM
I forgot, Im assuming you have 20inch aftermarket tires. With 22s though, a 12 is close to what the stock is with 20s.
Old Apr 17, 2004 | 01:15 AM
bagz's Avatar
when im doing donuts its real easy for me to flip even though i lean to the inside of the turn .. is it supposed to be that easy?
Old Apr 17, 2004 | 04:03 PM
AngryHampster's Avatar
if you're on pavement...yes.
If you're on dirt you need to lean more.
Old Apr 17, 2004 | 04:08 PM
Heres one really easy handling mod. Flip your rear tires around to make it a few inches wider. It helps, only downside is you have to air em up from the inside side, but its not much inconvienence.
