*******KFX 700 Questions *****
Old Apr 17, 2004 | 12:26 PM
Grinderdogg's Avatar
Default *******KFX 700 Questions *****
question 4 yall, ive got a 04 KFX700 that my local techs did over but it dont seem right, i am over 2000 ft elevation...ive got the K&N filter Kit, DMC duel Alien exhaust system and EPI 56g weights. which EPI said was the onlything i needed to do with the clutch for maximum performance with the other stuff added. I also dont think the jetting is right anyone know what might to try for jetting?it seems to bog down a second low to mid range, but not a case of burning to rich... also think EPI is right on the clutching? cause it seems to have more snot stock. thanx[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Apr 17, 2004 | 01:05 PM
Pistonman's Avatar
Welcome to the Forums. What jetting do you have now? If it is stock, it's going to be lean with intake and exhaust mods.
Old Apr 24, 2004 | 12:18 PM
I think stock is 145/142 and its currently @ 148/145, does other things have to be adjusted like the pilot jets or slide?
Old Apr 24, 2004 | 12:46 PM
KevinM's Avatar
If you're still running the stock spring with the 56 gram weights then its not going to run any better than stock even with the duals.
Old Apr 24, 2004 | 01:19 PM
Pistonman's Avatar
145 f - 148 r ? shim needles .020 also. read plugs, do as Kevin M. says and change primary spring. Open up the airbox. Probably have to continue jetting up , maybe not....read plugs...mixture (pilot) settings usually between 2 and 3 turns out S/B fine tuned.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
