someone give a little help with no spark
i've read most all the post about no spark, but i can't seem to find out is how to check the mag and or stator. i've got this far.
The bike does not start.Do the lights work with it off, do they work off just the battery, assuming they did before any problems. I know they work when you jump current into the middle of the circuit. How many wires of the magneto, 3 or 4? There should be 4, one for the coil charge, one to "pulse" the coil (make it fire), one for the lights,and a ground I believe. For a blaster they are white/red for coil pulser pickup,Yellow/red for lighting coil,and blue or black red for the source coil. resistances are 240ohm for source,20 ohm for pulser, and .2 for lighting I believe.(figs and color codes are for blaster, they give you a referenc,I'll try to get your figures tommorow,along with your color codes) [This message has been edited by fastblast (edited 09-28-1999).]
i've got 4 wires the above mentioned colors. black red for the source coil.
now how do i ck. resistence the ground and blk./red and read and should have 240 ohm. and so on for the rest?
thanks for any help. john
