raptor probs
Old Apr 18, 2004 | 02:58 PM
xraptor660rRider's Avatar
Default raptor probs
my 01 raptor is makin wierd noise first like some bangs cause i was doin tonights an wheelies then i was driven on the trail an it starts screamin it all sound like its in the rear end can u help me ?
Old Apr 18, 2004 | 03:07 PM
sixsixT's Avatar
Axle bearings???
Old Apr 18, 2004 | 03:22 PM
would that make it squeel an trhen make the bang sound .......... how much is that
Old Apr 18, 2004 | 04:00 PM
kuz28's Avatar
Axle Bearing. do not drive to duplicate sound for your buds. your causing damage to the inside carrier as the now loose steel ball bearings grind into the soft aluminum swing arm and carrier. you can rile and grind the damage away. but it's tedious work if you don't have access to air tools and a whiz wheel.
Tip: i've done this job several times for buddies who love driving their raptors in water and mud all the time.
the first couple times i was cautious and "tapped" the Bearings and seals in and out. and it took me 6hrs. day wasted no riding.
the last couple of times i had access to a heavy duty vise and i "whacked" the bearings and seals out. and wrapped the job in a couple hours.
Advice: fill that carrier with grease.pack it. i know. i know.. the bearings are sealed. so what! fill it with grease and that will keep the water out longer. good luck. the axle nuts are a real joy.
Old Apr 18, 2004 | 05:30 PM
thanxs alot thats wat it is we just checked
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
