I have a question?
Old Apr 19, 2004 | 02:54 AM
Haulinonthedunes's Avatar
Default I have a question?
I took my direct carb mount filter off and put the air tube and the K&N that goes with it back on. I noticed that when i put the tube and filter on it, it made it kind of sluggish through first second and have of third gear. Would doing this make me have to change my pilot jet. Because when i get about 5500rpm's (or somewhere around there) the power comes on really stronge like it is suppost to. So i know my main jet is ok but i was needing to know should i change my pilot jet to make it leaner or do i need to make it richer? I think i need to make it leaner but i am just making sure because i am not a jetting expert. Thanks for all the help. [img]i/expressions/face-icon-small-smile.gif[/img] Lance
Old Apr 19, 2004 | 03:21 AM
Sandaholic's Avatar
I would try to adjust the air/fuel screw on the bottom of the carb first. This is on the stock carb right?
Old Apr 19, 2004 | 03:41 AM
BlackHawk's Avatar
The air / fuel screw as well as the needle perhaps. set the air / fuel screw at either 2.5 or 3.0 turns out, i don't think anyone has ever done anything different from that. (except for 2.75 turns out!)
Old Apr 19, 2004 | 10:44 AM
SANDMAN430's Avatar
sounds like a needle but are you sure you have a large enough main jet i have went up a lot since i did the air tube k@n 142 to 160 hugh jump temp rise was part of that also
Old Apr 19, 2004 | 02:06 PM
CountryJoeGlass's Avatar
If I remember right Haulinonthedunes has a TM45 carb. I don't know if that makes a diffrence on the info that ya'll are giving him.
Old Apr 19, 2004 | 04:15 PM
SANDMAN430's Avatar
mine is based on the 45 also.
Old Apr 19, 2004 | 05:08 PM
Thanks guys for all the information. I am running the TM45. I didnt think about the air/mix screw but i will try it. Thanks for all the help. [img]i/expressions/face-icon-small-smile.gif[/img] Lance
Old Apr 19, 2004 | 05:19 PM
BlackHawk's Avatar
I was talking about the stock carburetor, so never mind what I said. I've never tried to tune a TM45.
Old Apr 19, 2004 | 11:23 PM
Well guys i found my problem didnt hit me until about an hour of thinking. Well ya know the vent hose on the right hand side of the air tube? I forgot to plug that hole and it was sucking air in, so i plugged it and problems are gone. LMAO That about my luck. Thanks for the help guys.[img]i/expressions/face-icon-small-smile.gif[/img] Lance
Old Apr 19, 2004 | 11:48 PM
XR650Warrior's Avatar
Next time we hook up at Kermit we need to put that DS on alky. [img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img]
