problems with Razr rears
Old Apr 20, 2004 | 01:17 AM
CroBiker's Avatar
Default problems with Razr rears
i have the new TRX450R and i put a set of Razr rear tires mounted on douglas .190 aluminum rims on it. i have the tires at the pressure suggested for the stock tires, but they seem to spin extremely easily. i'm used to riding mostly sand, but when i used to ride my 400EX on trails the stock tires hooked up better than the Razrs do on the 450R. should i lower the tire pressure, or what?
Old Apr 20, 2004 | 10:52 AM
trx250Rob's Avatar
First, what tire size and rim size did you get? If the razrs are stock size just let the air out a little. Try 5 lbs of pressure.
Old Apr 21, 2004 | 01:44 PM
thomez's Avatar
If you ride mostly in sand why in the heck did you buy a Razr???
Old Apr 25, 2004 | 03:07 AM
CroBiker's Avatar
i have paddles for the dunes, and the tires are almost the same size as stock. the recommended pressure for the 450R stock tires is 4.7psi +- .7 maybe i'll try jus under 4 next time
Old Apr 25, 2004 | 01:17 PM
OutOfControl's Avatar
Cro, Keep in mind, The 450 has a lot more power and torque than your 400 did. Or it sould have anyway.
Old Apr 26, 2004 | 07:41 PM
Boxhead's Avatar
With my warrior I have no problem spinning razor2's even on sharp corners, with 5 psi. I would of recommended the razor2's, they probably would of done better in your situation. That should be your next choice probably, but that's just a suggestion. Just drop the pressure a lil' bit for now, that's the best you can probably do. I have no idea why people say they have problems getting the rear end out with the razor2's, it seems pretty simple.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
Sjrpp
Jul 5, 2015 09:04 PM
