400 to 440 now won't start.
Old Apr 20, 2004 | 03:22 PM
BingeNut's Avatar
Default 400 to 440 now won't start.
I have a 2001 400 EX, that I just had a Wiseco 440 kit installed, along with a cam and rocker arms. The problem is since I have had the kit installed is the bike will not start when it is cold. It will start almost instantly with a pull from another machine, but will not start on the starter. After it is warm it will start no problem on the starter. I have installed a new battery and I have had the starter rebuilt. Any more ideas as to what the problem could be.
Ohter info: K&N power kit installed, rev delimiter installed, FMF power bomb header and white Bros. e series slip on installed. (all these were installed before, and the bike started fine.)
Any help would be greatly appreciated.
Old Apr 20, 2004 | 05:34 PM
cals400ex's Avatar
i assume you don't run an aftermarket rev box??
i would raise the pilot jet up to a 42 and that should help.
also, i would imagine that the new cam your running doesn't have the decompression mechanism on the cam unless it is a honda cam. this would make the bike a little harder to start. you might consider buying a new plug too.
Old Apr 20, 2004 | 06:10 PM
fred600rr's Avatar
i had the same thing with mine i didnt have enough copression to start its a quike easy check and cheap for a mechanic to do and make sure your valves are adjusted right or its not going to start
Old Apr 21, 2004 | 09:32 AM
BingeNut's Avatar
Cals, I am running an aftermarket rev box, I guess in my description I called it a rev delimiter. I will try raising the pilot jet to a 42 and see if that helps, I did put a new plug in, but I will change that at the same time.
fred600, I know you should never assume anything, but I assumed that with the new kit installed there would be all kinds of compression.
Thanks for the replies.
Old Apr 21, 2004 | 10:08 AM
SANDMAN430's Avatar
mine wouldn't start at all it was the decompression lope we removed it now it starts fine also heard that problem is a sign of cdi going bad.
Old Apr 21, 2004 | 06:17 PM
cals400ex's Avatar
depending on the brand of the rev box, they make the bike hard to start in cold weather too.
Old Apr 21, 2004 | 06:30 PM
KGB's Avatar
KGB
What he said......
Ditch the box, that motor signs off alot before the rev limit anyway......
Old Apr 22, 2004 | 08:38 AM
BingeNut's Avatar
Guess I will try that first, sounds like the easiest thing to try.
Old Apr 22, 2004 | 01:12 PM
BingeNut's Avatar
Originally posted by: BartlettRacing
put the stock cdi box back in it !!!!!! that will probly solve all your problems ........!
We have a bingo, put the stock cdi back on and fired right up.
Thanks all for the info.
Old Apr 22, 2004 | 03:48 PM
Kybol's Avatar
Check the decompressor, I have seen a few not start because of it.
