tire question
Old Apr 20, 2004 | 09:17 PM
blasterrider04's Avatar
Default tire question
i just got a new 400ex stock rim and tires on it r 20x10x9 i was wondering if 20x11x9 tires will fit on the stock rim
Old Apr 20, 2004 | 09:21 PM
fanke19's Avatar
These should not be a problem. In fact...in most situations you can get away with an even larger tire "width" difference. For example...Turf Tamer 18x11x8 tires and 18x9.5x8 tires both are mounted on the same 8x8 wheel. As long as the rim diameter size of the tires are the same, which are usually the last set of numbers in the size description, you should be ok.
Kyle5050
Dec 13, 2019 04:25 AM
toonces
Oct 16, 2019 12:11 PM
Ean
Aug 28, 2015 09:39 AM
Jul 24, 2015 11:57 AM
baysport
Jul 23, 2015 11:37 AM
