Spark Arrestor 97 Warrior???
Old Apr 20, 2004 | 10:02 PM
bwiley's Avatar
Default Spark Arrestor 97 Warrior???
does anyone know how to pull the spark arrestor out of a stock exhaust on a 97 warrior?????
Old Apr 20, 2004 | 11:03 PM
warrior68man's Avatar
Well...the baffle is attached to the spark arrestor so I am assuming you want it to be louder? Just removing the spark arrestor wont do anything....the baffle will
So, if you are only wanting to remove the spark arrestor, I can't help you....but if you want to remove the baffle and spark arrestor heres what you do..
1.) Take off pipe from quad, remove bolt from the end.
2.) You will need some source of heat (Mapp Gas, Excedeline w/ or w/o oxygen) to heat the pipe up the endo up the pipe.
3.) Use a chisel or strong small screw drvier to pry the spark arrestor out of the end of the pipe...
4.)Keep heating and prying and heating and prying...eventually it will come free
5.)That's all.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
Ashley S
Jul 31, 2015 09:46 AM
