250R won't idle!!
Old Jul 24, 2000 | 04:47 AM
qwik250R's Avatar
It runs great it just won't idle. I tried screwing the choke **** up and down but no luck. Help me please, it's really gettin on my nerves.
Old Jul 24, 2000 | 10:11 AM
hondatrx300ex's Avatar
you should have an idle screw on the carb.......I was once told that a racing 2 stroke engine wasn't supposed to idle...later
Old Jul 24, 2000 | 10:28 AM
retro's Avatar
Clean the carb and the choke/idle assembly. Your jets might be plugged. If your throttle cable is stretched out too much, you may have to adjust the part by the thumb throttle. Screw it out, and your idle should go up in RPM's.
ERIC
Old Jul 25, 2000 | 12:08 AM
250Racer's Avatar
Check your main jet and bowl for dirt. Set your idle air screw back to the factory setting. Depends on the year. My 86 is 1 and 7/8 turns out. Did you check and clean your air filter. Make sure there is not a broken or cracked reed if nothing else. If you still dont get it you may need to go deeper in the carb. Good Luck!!
86 250R
to many mods to list
Scooter's Shop
23
Oct 22, 2015 07:04 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
