exhaust valve
Old Apr 21, 2004 | 05:16 PM
BIGGONE's Avatar
Default exhaust valve
Hey guys!
Here's a stupid question, I"m guessing , How do you know if your exhaust valve is workin?I've got the LT250 '89
I look in the window and it doesn't do anything, I run the throttle while looking in the window and all I see is the arm linkage jiggle alittle bit.So how do I know if it's workin right?Is it supposed to have more than just a jiggle to it?I'm thinking it should have noticable movement???
Hey zigzilla if you read this my quad is right above yours on the quadracer forum.
Old Apr 21, 2004 | 05:37 PM
waynaferd's Avatar
I had to take mine out and clean it. It was pretty gunked up and was hard to turn....Still not sure if I noticed a difference....
Old Apr 21, 2004 | 07:08 PM
LT250Rodney's Avatar
Youll likely have very poor top end performance. It wont have that surge of power when it flips. Thats how I know mines working anyways. When I put the cylinder on last time i turned the spring the wrong way, and it wouldnt even wheelie. It just doesnt have that arm stretching power surge (what rookies call the "powerband") when the valve flips.
Old Apr 21, 2004 | 10:07 PM
budrud's Avatar
I find it's very noticable if it's not working. Make sure the lever is down when not running and if you take the cover off it should move up and down easy. I find it's easy to get the spring preload goofed up so take the adjuster off on the other side and make sure it's right.
Bonzhonda300ex
Sep 17, 2015 10:44 AM
bvolks
Sep 13, 2015 12:57 PM
black798
Sep 9, 2015 07:42 AM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
