raptor problem
Old Apr 22, 2004 | 11:36 PM
alaskarap's Avatar
Default raptor problem
Has anyone else had the 6 bolts that connect the one way starter to the ac magneto shear? Mine has done it 4 times and the guys at the yamaha shop here are not that smart. Can anyone help me?
Old Apr 22, 2004 | 11:58 PM
RaptorOwner's Avatar
I have done mine by myself and have never worked on a motorcylce engine in my life and they have been working for 9 months now. I just torqued them to specs but they are probably using inch lbs instead of ft pounds.
Old Apr 23, 2004 | 12:03 AM
alaskarap's Avatar
well i don't think that is the problem. since this is the fourth time and each time i've done them to spec and used loctite everytime. it's shears them right between the starter assembly and ac magneto.
Old Apr 23, 2004 | 12:10 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
it happens
usually because the bolts untorque themselves
clean the bolt holes (of lubricant),,,,,,and use some red locktite
the bolts must be seated properly (locktite/torque)
(my oneway needs replacing as we speak,,,,,bolts sheared i think)
Old Apr 23, 2004 | 12:21 AM
alaskarap's Avatar
I just talked to someone about it, I guess it has something to do with the mixture screws on the carbs. And it backfires when you try to start it and sends the crank the wrong way against the starter and shears them. I just need to know the number of turns for each mixture screw.
Old Apr 23, 2004 | 02:42 PM
KingoftheRaptor's Avatar
go with the L & A Designs and you will be fine. I went through two one ways before the l&a and it's awesome now.
Old Apr 23, 2004 | 05:12 PM
Bing's Avatar
Super Quad Patrol
bump the idle up a bit (richen the idle circuit),,,,,,and use the clutch and leave in neutral when starting and shutting off
If I had it to do over,,,,,I would have replaced with the L & A when I 1st started to notice a problem
My stocker lasted over 2 years
Old Apr 23, 2004 | 05:38 PM
Yes this is what I do now and never had a problem since. I dont know if backfiring would cause this at all. I think your bolts are coming loose. If it were tight the gear and the magneto would be considered one object to me. Are you using factory bolts or ones you got from a hardware store?
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
