400ex suspension
Old Apr 23, 2004 | 12:30 AM
keepitpinned's Avatar
Default 400ex suspension
In time im going to be getting a 440 kit for my 400ex. Will i need to widen the a-arms and axle, and also get a longer swingarm. I want the thing to be stable and not tipsy. will the stock suspension be ok when i get the 440 get. I ride mostly backroads, trails, and hit occasional jump. also how wide should the a arms, axle, and swingarm be if i need it bigger?
Old Apr 23, 2004 | 01:19 AM
DaSandBomb's Avatar
stock is fine. if you wanna go cheap like me just get 250r front shocks. they are much better then stock 400 ones, beacuse you can sorta adjust them. and it makes your front end a little lower, so it sorta looks different and the ones i have are blue so they kinda look like works shocks
- kc
Old Apr 23, 2004 | 09:25 AM
RedEX's Avatar
For that type of riding I see no reason to mess with the suspension unless you just got a lot of extra money burning a hole in your pocket.
Old Apr 23, 2004 | 10:08 AM
SANDMAN430's Avatar
stock works fine with that set up.
Old Apr 23, 2004 | 04:32 PM
so with the extra power of the 440 it wont be tipsy? i want it to be stable at higher speeds
Old Apr 23, 2004 | 05:26 PM
RedEX's Avatar
Your not going to go any faster with a 440 (not much anyway) - you'll just hit top end faster. If you want more top end speed - look to changing the sprockets to change the gear ratio.
Old Apr 23, 2004 | 11:14 PM
why do you say that? with a 440 and other little things done it is one mean machine
Old Apr 24, 2004 | 04:22 AM
cals400ex's Avatar
not with the stock cam
Old Apr 24, 2004 | 11:34 PM
ill get a aftermarket cam then
Old Apr 25, 2004 | 04:43 AM
cals400ex's Avatar
that will make a difference then.
Robinhood
Dec 26, 2015 10:28 AM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
