03 p360 actuator ( 4wd/2wd) light
Old Apr 23, 2004 | 01:24 PM
trailblazermudrunner's Avatar
Default 03 p360 actuator ( 4wd/2wd) light
my moms p360 actuator or i think well i get to the problem the 4wd/2wd indector light comes on and blinks every 0.5 sec and the tech says it is the actuator and the quad will pull it self with even touching the gass help!
Old Apr 23, 2004 | 01:32 PM
nyroc's Avatar
The .5 second flashing means failure of the 2wd/4wd actuator.
Pulling itself without giving it gas means the idle is too high or the belt is too tight. You ought to be able to hear if the idle is high. Lower if if it soulnds high .The belt is easy to loosen. I have instructions on my website. It is almost identical to the 650, so look for 650 belt adjustment.
The 2wd4wd actuator may not actually be bad. Check connections and fuses. It is possible that the controller is bad. You need a manual to tell if the actuator is bad yourself. You need a voltmeter to check it.
If your actuator is bad and the shop replaces it, can you give me the old one? I am trying to get a bad one so I can figure out a way to make a vacuum operated one to help people out that run theirs in the mud a lot. I will pay shipping.
Old Apr 23, 2004 | 01:45 PM
thanks for the info if i can get it to the shop some time next month ill have them test the actuator for me ill have them order the new one and be for they put it in ill have them test it and then ill go from there and ill get it if it is bad. if u give me 15 to 20 bucks ill pay to ship my self ok. do u think it will hurt it to drive it like that[img]i/expressions/face-icon-small-confused.gif[/img] im confused help!
Old Apr 23, 2004 | 03:08 PM
nyroc's Avatar
Dont drive wil the belt too tight.
You can drive without 4x4.
Old Apr 23, 2004 | 05:22 PM
o thanks that helps if we get the old actuator do u still want it
panicmanic
Sep 28, 2015 12:59 PM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
Alex G.
Sep 16, 2015 12:13 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
