Trailblazer Questions
Hello, I have a 1996 trailblazer 250. Im having several problems and I cant get ahold of an owners manual so I figured I could ask on here.
The headlights,breaklights, and extra headlight dont work on the bike, I do think its a fuse because the bulbs dont look burnt up or anything. Where is the fues box at?
I can't seem to find where to change the oil at on it, I looked around but didnt find a drain plug or a place to check it? Also does it take oil and filter? And if so where can I go to get the oil and filter it requires.
I noticed that the seat lifts up but I can't tell how and I dont want to force it and then have it break?
What brand of sparkplug would you reccomend?
And one more thing, what is the cheapest, easiest mod I can do to it to add some power.
Thankyou!
Thankyou!
the fuse im not to sure but the oil it should be a two sroke oil injected as far as the seat the is a lever on the left side pull up on it. There is many mods you can do so that is all up to you .I all so do have a manual for that year if you have any mory que. feel free post and ill try to reply as quck as i can
it is oil-injected, fill the oil on the front hood. go w/ NGK spark plugs. The fuses shou;ld be under the front hood. Take to oil cap off, and pull up, it should just pop off. You should get a pipe, easy and cheap. Also, get a K&N air filter if you do not already have one. Write back and we will answer any questions you still have.
Welcome to the Forums! [img]i/expressions/face-icon-small-smile.gif[/img]
