yet another rejet question
Old Apr 25, 2004 | 02:28 PM
hondarider300's Avatar
Default yet another rejet question
i just drilled 35 1/4" holes in my airbox lid, should i rejet it or no? i have had the mods in my sig rejetted and im wondering if i will need to do it again since i drilled holes. Also, i think its jetted a little bit lean already because ever since i put on my pipe and jetted it, its been hard to start the bike cold, and somtimes it back-fires. Thanks for any help.
Old Apr 25, 2004 | 08:43 PM
Rider1169's Avatar
well, if its lean still, u might need to jet it down smaller, u wont have to rejet it any bigger for the holes if its back firing, that means too much gas, its not all burning, if this persists, jet it down anywhere from 5-30, depending on how bad it is
Old Apr 25, 2004 | 10:24 PM
cals400ex's Avatar
if it is lean, jet UP, not down. when putting holes in the lid it leans the mixture out meaning you need to go LARGER on the jets.
Old Apr 25, 2004 | 10:31 PM
so maybe since its already a little bit rich (backfiring) the holes in the lid will equal it out so it will be leaner and jetted better. does anyone know if its hard to start does that mean its rich?
Old Apr 26, 2004 | 04:26 PM
cals400ex's Avatar
if it is hard to start it is probably lean on the pilot jet.
Old Apr 26, 2004 | 04:58 PM
hmm well ill give it a shot and try it out with the jetting now. If i notice any changes or anything unusual ill post again. Thanks for the help
Old Apr 26, 2004 | 10:26 PM
cals400ex's Avatar
those jet kits don't come with pilot jets. you can try turning out your fuel skrew on the bottom of the carb 1/2 a turn or so and that will richen it up a bit. the lean condition on the pilot jet/fuel skrew causes some popping. the fuel skrew is a fine tune adjustment for the pilot jet. however, most people i talk to run a 40 or 42 pilot jet in their 300ex and 400ex
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
