185 carb rebuild ?????knows or thrash
Old Apr 25, 2004 | 04:04 PM
ridehard2's Avatar
Default 185 carb rebuild ?????knows or thrash
hey knows or thrash i read in the 185 carb post that i need to change the main jet, pilot jet, needle taper to upgrade my 185s carb. Where is the pilot jet, needle taper? my clymer does not point these out. also it says my slow jet is pressed in but my screws out and is part of my rebuild kit. I looked with the naked eye and things look the same as the parts in my 185s carb. Ibought a 200 kit to rebuild my 200 and was going to change the stuff from my old 200 carb and put it in the 185. the only thing wrong with my 200 was the float valve everything else ran good any help would be appreciated [img]i/expressions/face-icon-small-confused.gif[/img]
Old Apr 25, 2004 | 05:56 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
here, this may help
Old Apr 25, 2004 | 10:08 PM
KNOWSALOT's Avatar
The Facility
ridehard2,
The needle taper is referring to the taper of the needle jet that came with the ATC200 carbs. It's the needle up top that goes up and down when you open and close the throttle.
Some kits come with the correct spec jets while others give you a few jets to cover different circumstances[year, elevation, modifications, etc]
Keep in mind that Honda never ran the same main jets in all the trikes even if they are the same model and same year. Depends on assembly line changes midyear and what elevation the unit was shipped to, so check and see what is your bike now before making changes.
Most 185 engines came with mainjets ranging from 92 to 98
Most 200 engines came with mainjets ranging from 95 to 105
Old Aug 17, 2005 | 10:05 PM
soulreaper2222's Avatar
hey does anyone here know where i can oreder a rear suspension kit for a 83 185s 3wheeler beacause i seen the kit on ebay and i really need it because i ride on real ruff terain and maybe you guys can help me out here well if anyone knows email me at (soulreaper2222@yahoo.com),i would really appreaciate it.
Old Aug 24, 2005 | 08:53 AM
GlennJ's Avatar
Kits are really hard to come by these days since they're not made any more. Your best bet would be get get 200X for other fully suspended machine.
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Mar 6, 2018 06:53 AM
kelleycully
Sep 15, 2016 02:57 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
yambam13
Jul 4, 2015 01:49 PM
