Front hubs question
I am doing a complete brake job on my 99 Polaris 500 Sportsman and noticed that there seems to be gear oil in there instead of grease. If it is gear oil, what type and how much should I put in it. Thanks alot!!
I use sythetic ATF in the hubs of my 99 SP seems to have less wheel drag than hub fluid and since the ATF is cheap fill it, run it and drain it a couple of times to clean it. I don't think you have to grease the the bearings as they should be immersed in hub fluid when it is filled properly.
Originally posted by: Bing
Mobil 1 synthetic ATF is what I use.
one bottle will last a long time.
JackTheKing
Jul 14, 2015 09:09 PM
