Front hubs question
Old Apr 26, 2004 | 08:19 AM
Quadder79's Avatar
Default Front hubs question
I am doing a complete brake job on my 99 Polaris 500 Sportsman and noticed that there seems to be gear oil in there instead of grease. If it is gear oil, what type and how much should I put in it. Thanks alot!!
Old Apr 26, 2004 | 08:42 AM
HighVelocity's Avatar
Use synthetic ATF in the front hubs.
Old Apr 26, 2004 | 10:53 AM
Quadder79's Avatar
I just talked to the dealer...he said to use hub fluid. Is that similar to ATF?
Also, should I grease the bearings AND use the fluid??
Thanks...
Old Apr 26, 2004 | 02:28 PM
highwayman's Avatar
I use sythetic ATF in the hubs of my 99 SP seems to have less wheel drag than hub fluid and since the ATF is cheap fill it, run it and drain it a couple of times to clean it. I don't think you have to grease the the bearings as they should be immersed in hub fluid when it is filled properly.
Old Apr 26, 2004 | 02:46 PM
lovemud's Avatar
Type F tranny fluid seems to work well also if you can't find any synthetic.
Old Apr 26, 2004 | 02:49 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
Mobil 1 synthetic ATF is what I use.
one bottle will last a long time.
Old Apr 26, 2004 | 05:14 PM
BigBadScrambler's Avatar
Roger that. You will be surprised how many "problems" can occur just from dirty hub fluid. I change mine a couple times a year. That stuff gets nasty and having that quart of Mobil 1 handy is nice. The tranny "hub" fluid provides the lubrication for the bearings. I find that the synthetic ATF works better for me than the Type F. Just dont mix the two
JackTheKing
Jul 14, 2015 09:09 PM
1966F100
Jul 12, 2015 03:08 AM
toonces
Jul 11, 2015 12:01 PM
200es
Jul 10, 2015 09:09 AM
jettman
Jul 6, 2015 12:16 PM
