jetting??
I am running a pro flow foam with no lid. I got a 150 and 155 jet in today and bike still runs lean without lid. With lid it did better. I also have 160 and 165 main jets but they are the fatter jets shaped like a mushrom . u cannot use the little sleeve with them though. Was wondering if u can use them or not, cause i tried them and still ran lean. I also moved the clip position down to the 4th slot. I also have one size bigger pilots but i didnt think i would have to do al this for just a filter with no lid. I could get it running good with the lid i think but i want to order the adapter to get rid of the air box so i want to see if i can get it running with no lid first. i also have about 10 9ea-9 plugs left from the 686 and was wondering if i could use them in my new bike or to stick with the stock ones.
Thanks Rudy
Thanks Rudy
is something wrong?? Right now it finally runs pretty good. I have 190 and 195 main jets and 25 pilots and clip on 4th slot from top. I didnt have that much jetting when i had the 686. Just dont make sence. I have stock exhaust with proflow foam with out pre filter and no lid.
Rudy
Rudy
thats what i am thinking. can something be plugged up maybe. i keep blowing in the holes to clean it out. But it wouldnt run barely until now.
Rudy
Rudy
is it possible. Its runing good but i am at 195 and 200 mains with clip on fifth spot with 25 pilote and about 4 and 1/2 turns out. I checked float, ok, checked for air leaks, found none. I put the lid on and it fouled a plug so that seems like i would have no air leak in boots or filters. Do they make bigger jets than 200. I am thinking about getting a jet kit to try that , what is better, dynojet or gytr???
Rudy
Rudy
