250r or banshee help!!
Old Jul 25, 2000 | 07:27 PM
Man666son's Avatar
ok im sellin my 300ex and buyin eithre a banshee or a 250r what do you guys think i should do? dont say buy the honda just cuz this is a honda forum, try to be as honest as possible
Old Jul 25, 2000 | 09:43 PM
kaydub's Avatar
man, i am telling you it's all about what you in it for.....if you like trails, corners, jumps, and that deal...go for the 250r. the frame is superior to the banshee in all of those categories. if you down for the straight aways, sand, hill climbs, and big roosts....go for the banshee. the banshee was made for that stuff, and yeah, you can jump big with a banshee, but i would prefer jumping on a 250r. better handling, suspension and more control in the air. you decide and good luck
Old Jul 26, 2000 | 08:39 AM
Man666son's Avatar
what about speed how much faster is the banshee than the r?
Old Jul 26, 2000 | 01:46 PM
RoostKing's Avatar
The 250 R will get waxed in top speed and acceleration. Like the former poster said, the Banshee rules the sand, drags, fires/logging roads, hill climbs, and last but not least, THRILLS. When that power band hits, SEE YA!!!!
RoostKing...
Old Jul 26, 2000 | 03:33 PM
jeepin's Avatar
It is really up to u.And where U ride.Sand wide open area's fire roads???The like the 2 proevios posters said banshee.I have a 86 trx250r it is moded alot.I ride MX only with it.But when i bought it she was completly stock and I roosted down all my trails and it was a great machine.But after the mods it is a little to wide for my trails and the front end it to light.I say 250r for woods and just messing around.
86 trx250r wiseco .020 piston,boyesen reeds,FMF gold series fatty pipe,power core 2 silencer,Dg alloy series nerfs,JD performance +2 A-arms,white bro's white power shocks with res's all the way around,durablue eliminator 2+2 adjustable width axle,durablue posi loc axle nut,Fastline braided steel brake lines,braking brake pads,motion pro twist throttle,motion pro clutch cable,PEP easy pull clutch perch and lever,20/11/9 6 ply razr's on ITP .190 wheels,18/11/8 holeshot mx's on mitchell .190 wheels,21/7/10 holeshots on ITP wide off-set .190 wheels.
Old Jul 26, 2000 | 03:57 PM
one1drboy's Avatar
Roostking,
How thick is your "powerband" 3/8" or 1/2"? Also what part of your body are hitting it with?
The honda 250r is a two stroke just like the banshee. They both have a "powerband", or a that magical point at which exhaust pressure builds in the expansion chamber to the point it acts as a "po-boy" turbo to increase the amount of fuel to be ignited and boosting the compression ratio of the engine by forcing exhaust back into the engine.
One bike rules the roost and long straights, the other rules everywhere else. Where do you ride? Are you going to race? Why do you limit you choices to those two bikes? Why is the sky blue? Where do babies come from? How much wood could a wood chuck chuck if a wood chuck could chuck wood?
Old Jul 26, 2000 | 04:33 PM
RoostKing's Avatar
one1drboy
Well, I suppose since its a thumb throttle, I am hitting it with my thumb. How thick is it? Well without a Tachometer, I cant be to precise, but Id say its about 5000 RPM thick. The sky is blue do to sunlight bouncing off the water. Babies from storks. OH yes, the powerband on the legendary 250r does not hit near as hard as the Banshee... One thing: How can the Banshee rule the roost, with the 250R ruling everything else? If you rule the roost, you rule, well, the Roost...Kinda a contradiction dont 'cha think?
Anyhow, Manson, good luck on your choice, either way, your made a few great choices...
RoostKing...
Old Jul 31, 2000 | 04:45 PM
kickAZZ250xer's Avatar
get a banshee nody has those at the dunes . then u will be real original.
Old Jul 31, 2000 | 09:11 PM
Dill's Avatar
just for clarification, a mildly modded R can beat a stock banshee..but a banshee can be built bigger for drag racing...but an R is a better all around machine, and with big bore kits available for it, its no slouch either.
Kaleb_00
Jun 1, 2016 09:15 AM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
Jul 7, 2015 11:00 PM
