500 ninja mojave
Old Apr 27, 2004 | 10:02 PM
odysseyjunk's Avatar
Default 500 ninja mojave
hey guys....just started the first fabrication on my project....looks like its gonna work. this motor almost looks stock in the mojave frame.....exept that it has 60 hp and 6 gears. you can see the frame in the background of my odyssey project. im just waitin on my next paycheck to buy a welder. im tryin to figure out a way to angle the carbs down a bit more to clear the frame on the mojave...anyone have any ideas?intake tubes are rubber, but i want to make it look as stock as possible
Old Apr 29, 2004 | 11:14 AM
BasicBajaX's Avatar
Keeps busy in the garage building one thing or another.
I got the exact same project started myself, I just havent had the time to finish it. Actually I have only got the frame streatched about 4 inches and everything is sitting in a homeade jig I made. I have ordered the tubing just havent picked it up yet.
Are you going to try to use the ninja fairing ,tank and seat?
Old May 8, 2004 | 01:57 AM
SpDdEmOn's Avatar
The only bad thing about this wicked project is that when you are done with it, you are going to find that you need major suspension mods because the bike now weighs 120lbs more. Have fun going over 100mph on a Mojave and try not to die doing it. Good Luck
Old May 8, 2004 | 09:52 AM
actually, a 500 ninja motor is only a two cylinder, and is only about 50 lbs heavier than a mojave motor....hehe im gonna post some vids when i get it done.....
Old May 9, 2004 | 02:13 AM
mudmaster250's Avatar
dirt wheels did this a while back(couple of years) and what they found was that it had way to much power for the chassis and the suspension to handle.
Old May 9, 2004 | 10:32 AM
ThreeWRacer's Avatar
who cares if it over powers the suspension its really cool. Good project. We put a 750 street bike engine in a snowmobile when people said it couldnt be done. But people saying it wont work just drives me more to complete it. When you take it for the first ride and dont like the suspensin, change it. You said your buying a welder. Lenghtin the a arms a bit and lenghtin the swing arm. then youll have one heck of a mojave.
Old May 9, 2004 | 10:35 AM
oh and about those carbs, can you angle the motar back a little. It looks tight so probably not. I wouldnt change the carb boots.
Old May 12, 2004 | 08:10 PM
SpDdEmOn's Avatar
Id like to have a 411 Mojave thats all done up. Too bad Mickey doesnt build them anymore. I like the Mojave, its a fun machine. Too bad its as underrated as it is.
Old May 13, 2004 | 06:14 AM
binfordw's Avatar
A friend of mine did a Suzuki 250R with a Kawi 500ex engine a while back. It didnt fit very well in that frame tho. It had alot of supension issues and was horrible in the woods, but it was fast and fun to play on. Make sure you get the engine sprocket lined up well- If its too high above the pivot point the chain with slack w/ compression and stretch with extension of the rear suspension.
Also, if the carbs wont fit i'd look into cutting the frame.
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
ljinx23
May 14, 2001 08:08 AM
spencer
11
Mar 17, 2001 07:36 PM
