Carb is leaking fuel from the drain.
Old Apr 27, 2004 | 10:57 PM
chris68's Avatar
Default Carb is leaking fuel from the drain.
I have a 83 185s and it was sitting a few years, drained the old fuel but when i put new fuel in, gas just comes pouring out of the overflow tube on the bottom of the carb. I didnt want to take the carb apart yet to see, i am thinking something is stuck or do i need to take it apart and get a rebuild kit. What would cause the fuel to come out like that?
Any suggestions.
Thanks,
Chris
Old Apr 27, 2004 | 11:11 PM
RoughRider01's Avatar
I would check to make sure your float isnt stuck first.
Old Apr 27, 2004 | 11:15 PM
chris68's Avatar
Any way to check if it is stuck with out taking it apart? If i take the bowl off, i think i may have to repace the gasket.
Old Apr 27, 2004 | 11:51 PM
Goombadi's Avatar
Usually you can get away without having to replace the gasket, what people usually do is strip the screws on the float . Dont be lazy, pull the carb off, there is no shortcuts in this. Pull off the carb and check the float valve , properly clean your main jet, pilot jet etc. this should take care of the prob, good luck.
micheleLeigh
Jul 12, 2015 02:50 AM
Unzzy66
Jul 11, 2015 10:01 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
Mikea1978
Jul 4, 2015 12:37 PM
