runing the finish
Old Apr 28, 2004 | 11:45 PM
keepitpinned's Avatar
Default runing the finish
im going to be getting a pressure washer. i want to know if the pressure causes to take finishes off parts of the quad. I dont want it to take the chrome finish off or any of the finishes for that matter
Old Apr 29, 2004 | 10:18 AM
SANDMAN430's Avatar
i'd worry more about electrical part they don't seem to mix well.
Old Apr 29, 2004 | 06:31 PM
SANDMAN430, what do you use to wash ur quad. i ride in mud a lot and can never seem to get it clean no matter how long i take. my neighbor has a pressure washer. i used it once n made it look like new
Old Apr 29, 2004 | 06:39 PM
lapeerbanshee's Avatar
we have one and you can change the pressure on the end of the sprayer.
Old Apr 29, 2004 | 07:34 PM
MolokaiRider's Avatar
I usually use Simple Green on the tires and inner fenders. After spraying it on and letting it soak, I hit it with the power washer. Takes all the crap off. Just be carefull not to spray too much (without diluting) on anything else, it will fade plastic and might possibly make wire sleaves or vacuum lines brittle. Simple Green is a concentated cleaner/degreaser. Also take care to move nozzle from the power washer back from anything vulnerable on your bike. I.E.: Seat, electronics, vacuum lines, etc.
You'll notice after a good preliminary soaking w/ water, then soaking w/ Simple green, then power wash tires...that your rubbler looks good as new. I even use it sparingly on anything that is really stained w/dirt. Works great, haven't found anything better. Also cuts back on the amount of elbow grease needed. BTW, use Armor All on fenders (outer and inner) after, keeps plastics shiny, and also creates a barrier for the next time you go riding. Makes cleanup even easier. Of course, using these products after each ride gets a little spendy. I guess it all depends on how clean you want to keep your bike.... Good luck! [img]i/expressions/face-icon-small-wink.gif[/img]
Customer Service #1
May 15, 2020 08:46 AM
kbazzy
Sep 26, 2015 11:26 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
