Raptor question
Old Apr 29, 2004 | 08:41 AM
zslate's Avatar
Default Raptor question
Are they durable and are they tippy? I have heard negitives bout these to areas. But I figure get some info from ya'll guys that actually have them. Thanks a bunch, I'm considering a new quad this summer, I want one w/ reverse either a Z 400 or a raptor thanks!
Old Apr 29, 2004 | 09:17 AM
UBETRUN's Avatar
They are more durable than a Z400, I never saw a quad fall apart before my buddy raced one. 01 Raptors had bad transmissions and there have been a lot of lessons learned when going into the motor. 02 and above have better transmissions and the major engine builders are putting out some darned reliable motor packages if you need more power. They are tippy with the stock suspension and tires. Every aftermarket part you can afford to add to the suspension will improve the handling. Tires first if you're tight for cash. A Raptor will never handle like a YFZ but you can make them handle pretty good with enough money. The Raptor has tons more motor potential than a Z400 or YFZ and it's an awesome trail machine right out of the box. If those were my choices, I'd take the Raptor without a second thought.
Old Apr 29, 2004 | 02:29 PM
radfastdude7777777's Avatar
the good thing about the 01 rappys is titanium valves i only had 2 problems with mine the carbs popping off and the one way bearing i got upp boots which solved the carbs which were 90 but i think are like 60 or 70 now and the one way bearing is 180 or 190 and my tranny is still good although reverse was always bad because sometimes you have to click down twice or up twice to get it back into 1st other than that i think its been great
Old Apr 29, 2004 | 02:45 PM
AlphaRaptor660R's Avatar
I've ridden the snot out of mine with no problems what so ever. As for being tippy, I've never tipped a single time.
Old Apr 29, 2004 | 02:52 PM
RaptorOwner's Avatar
I have both bikes and like to ride both but drag race with my Raptor. But, you can make the z400 fast too!!! I like the bottom end on the Raptor, stock for stock the Raptor has way more bottom end.
Old Apr 29, 2004 | 04:05 PM
garyc660R's Avatar
HUH?
Old Apr 29, 2004 | 05:17 PM
zslate's Avatar
anything better bout the z400? Just wonderin'! My buddy got a banshee will a raptor keep up w/ it in the woods? My trails are purty tight mainly. So if you get a raptor make sure it is newer that 01 and I would be in good shape? Thanks I really appreate all this!
Old Apr 29, 2004 | 07:52 PM
Hayseed's Avatar
If you've got tight trails the Z400 will probably get you through them faster, stock for stock. I personally don't like the way my wife's KFX handles. It seems "jerky" to me. My Raptor is 2" lower, 2" wider, and 4.5" longer than stock so it handles pretty good. I also enjoy the extra power the Raptor has. As for the tippy issue, the more you weigh, the tippier they feel.
Firefighter400
Oct 8, 2022 06:38 PM
Aug 21, 2015 01:23 PM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
yambam13
Jul 4, 2015 01:49 PM
