Starter Enrichment Valve
Old Apr 29, 2004 | 02:15 PM
MrPlow's Avatar
Default Starter Enrichment Valve
Ok here is the deal. I took my choke cable off the other day to find out it was still good but the Enrichment valve was bad. I bought a new one, and there is a spring that goes in there. I bought the newest service manual for it too and it does not show me how this thing goes back together. Anyone with help?
Old Apr 29, 2004 | 04:50 PM
hondabuster's Avatar
carb pic
Its not the best diagram...but might help.
Old Apr 30, 2004 | 07:43 AM
dzzy's Avatar
It goes like this...put the rubber dust seal on the cable and push it up out of the way, install the cable in the metal holder so you can see the end of the cable, install the plastic nut, install the spring and compress it carefully and put the plunger on the end. The spring goes between the plastic nut and the plunger itself. If it looks like it's nearly impossible to do, you might consider replacing the cable. Sometimes the cable comes apart a bit a the top and doesn't leave enough slack to assemble the carb end.
ghost civic
Jan 15, 2020 07:43 AM
Austins
1) Engine problems..
Aug 9, 2015 02:28 AM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
