98 warrior has no spark
Ive got a 98 warrior and it was running fine the other day. I parked it and went to ride 2night and it will not start i messed with it for quite a while and still wont start. im sure its getting gas bc i can smell it. what would be some possible problems for no spark??
possiblely a bad connection my warrior does that everytime I wash it! I think it has to do w/ all the wires under the left rear fender! I wiggle them a lil bit a try it then wiggle it again and make sure there ain't no wires hang off and that everything looks good and most of the time it starts. But did you get it wet before you put it up if so it just might needs some time to dry!
Dont listen to these people.....rofl oil causes no spark what the Fk is that rofl.....Get a dc power tester test all wires goint into your CDI box if they dont all have power check your wiring....if they do all have power then check all of your wires coming out....The Orange wire is the wire going to your coil...if this wire has no power then its either your CDI box or your stator....if it does have power then i would recommend getting a new coil....I have had this same problem several times....Warriors electrical systems are crap, i would recommend gettin a programmable CDI box if you end up buying a new one and also instead of paying $ 350 for a stator from yamaha go here Ricky Stator
