click from warrior
Old May 1, 2004 | 03:01 PM
BANSHEEBOY88's Avatar
Default click from warrior
A couple weeks ago I went to start my warrior and when I hit the button all I got was a click. I changed the battery today and it is still not startin what do you guys think it is.
Old May 1, 2004 | 03:03 PM
duke9074's Avatar
thats a common problem on fords. its usally there seliond. try to connect the seliond prongs with a screw driver see if it works then.
Old May 1, 2004 | 03:04 PM
tryed that and there is no spark between them, and the motor is not turnin over
Old May 1, 2004 | 05:13 PM
bagz's Avatar
fords????
Old May 1, 2004 | 10:03 PM
Wickedclownz's Avatar
most annoying problem ever, i still have that same problem, tryed replacing selenoid, tryed replacing battery all the connections are tight and clean, went to my local yamaha dealer and they said it was because my battery wasnt powerful enough, well i got home put in the new battery did the same thing then i busted my negetive battery wire... lol figures one problem after another if anyone has other ideas im all ears
Old May 1, 2004 | 10:10 PM
2000IAWarrior's Avatar
well just had the same problem on my warrior 2 weeks ago and on a 2000 2 years ago.. and well u need a new starter.. either that one rebuilt if its rebuildable or get a new one.. check ebay u can get new one for 125 deliverd to your door... pull your starter out and take the 2 bolts that hold it together.. as soon as i pulled those 2 out you could smell the burned smell ist eh burshes are bad.. you can rebuild it.. if you burned ne thing into the armator the thing that brushes rub on.. its JUNK
Old May 1, 2004 | 11:56 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
^^^ hey u stole what i was gonna say [img]i/expressions/face-icon-small-tongue.gif[/img]^^^^
Old May 2, 2004 | 12:54 AM
bagz's Avatar
lol
Old May 2, 2004 | 12:05 PM
well i replaced the solinoid and it still doesnt get spark between the two, and im still just gettin a click. So are you guys sure it is the starter because those are kinda pricy.
Old May 2, 2004 | 08:09 PM
im in the same situation and i honestly think i should take it in and get it looked at because first i made a thread asking and everyone said it was the selenoid then the battery and well i already mentioned all this but 130 dollars later my quad still doesnt start...
