click from warrior
Old May 4, 2004 | 08:37 AM
  #21
reconman2003's Avatar
Default click from warrior
is there a back up recoil or kick start?
can u run start it?
Old May 4, 2004 | 09:26 AM
  #22
2000IAWarrior's Avatar
you can run start it.. put in 6th gear and go down a big hill or have someone pull or push you.. a honda 300 4x4 bumper is perfect to push you8.. haha.. i have seen recoil starters i think Alba carries them.. not totally sure.
Old May 4, 2004 | 11:28 AM
  #23
UltimateAussie's Avatar
on the farm we have alot of old trucks it ususaly ends up being the starter solenoid.
hope it helps
Old May 4, 2004 | 02:27 PM
  #24
yamahawarriormods's Avatar
same sh$# happend to me i tried everything then it just worked dont know how dont think it was the starter cause it still works till this day GOOD LUCK !
Old May 4, 2004 | 03:55 PM
  #25
warrior387cc's Avatar
okay if there wasn't a spark then the problem isn't your starter
it has to be from the selinoid to the battery
when mine did the same thing my selinoid sparked w\the wrench between
it so it had to be from there or forward hope this helps.
Old May 4, 2004 | 05:04 PM
  #26
BANSHEEBOY88's Avatar
so now you DONT think it is the starter because there is no spark between the solinoid.
Old May 4, 2004 | 07:42 PM
  #27
muddbogger's Avatar
replace the fuse and if its not that its that "selanoy thing"
Old May 4, 2004 | 08:20 PM
  #28
where is there a fuse i can replace
Old May 9, 2004 | 02:45 PM
  #29
well i checked the fuse and that is alright, and then i hooked some jumper cables to the possitive side of the solinoid and put the other one to ground and it still didn't start, any other suggestions.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
kbazzy
Sep 26, 2015 11:26 AM
Bernhard
Sep 25, 2015 12:45 PM
Jersey General
1) Engine problems..
Sep 13, 2015 01:05 PM
