Sport Quads Discussions on sport quads.
took out the pred and tb......now they dont work!
Old May 3, 2004 | 11:43 PM
simster570's Avatar
Default took out the pred and tb......now they dont work!
Hey guys I just got back from going ridin with one of my buddies(who doesnt have a quad, he borrowed the trailblazer, but hes gettin ready to get a z400. Thanks for listining LOL) OK here is what happened:
We got the 4wheelers to the place, It had just rained and there was alot of mud and water everywhere, along with some really good-sized hills. We rode for about 30 minutes in mud, about a foot deep or so water steep hills, when all of a sudden the predator just died and wouldnt start back up. It would start up every now and then with the choke on, but as soon as I gave it any gas or took the choke of it would die. It had compression, and the battery for the electric start was very strong. It also had plenty of gas. My friend went to go get a chain to pull the pred back to the truck with a chain, but after about a minute I see him walking back to where I was saying the trailblazer dies right in some water, about 8 inches deep. It wouldnt start, there was plenty of compression and gas, and it woulnt start with the electric or pull start. So we had to go get his truck and go get them and go home.
Does anyone know whats wrong??? This really pi$$e$ me off, especiallyabout the not-even-a-month-old predator.
I think maybe there is some water in the carbs, I mean water was going everywhere when we were goin thro the water. If anyone knows whats wrong could you please explain what I need to do to get them running again and if there is anything I can do to prevent this from happening again.
PS The pred is a monster in the mud when it works!
Old May 5, 2004 | 06:26 PM
emac's Avatar
take off the carbs on both machines clean them, maybe drain your gas tank, clean the airfilter put it all back together and see what happens, my best guess would be you got some water in your gas or carbs etc.
Old May 6, 2004 | 04:19 PM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
do what emac said and check the jets to, make sure there is no dirt or grime in them.
Old May 6, 2004 | 06:05 PM
whitebroskfx440's Avatar
get a new spark plug?
Old May 6, 2004 | 06:09 PM
GSXRPred's Avatar
Happens to me all the time on my pred. Look at your carb, it should have either 3 or 4 vent tubes running from it going to the bottom of the quad. Find the ends of them, clean them off, then relocate them up next to the air box and this should fix your problem.
Old May 7, 2004 | 01:13 AM
simster570's Avatar
OK I got them fixed now. Thanks for the input from all. The tb was easy, just drained the carb and ejected the water out of the cylinder and it started right up. The pred was a little trickier tho. I had drained the carb and ejected the water from the cylinder, and it still did not start. After thinking about it for a while, I figured maybe water had gotten in the fuel filter and caused it to swell and was not letting any gas through. So I took out the spark plug and put a couple drops of gas in the cylinder with an eyedropper and put the spark plug back in and tried it. It fired up perfectly like it was nothing, sputtered a bit, the ran strong from there. Turns out I had an air bubble in the line whitch was not letting gas get to the cylinder. It runs kinda rough right now tho, Ill probly change the spark plug and the fuel filter and a couple other things anyways. I also re-routed the vent tubes.
Old May 9, 2004 | 01:55 AM
04LERaptor's Avatar
Dude if you had water in the cylinder, you where not just playing around in a little water......you where jumping in it and sinking down it in some deep stuff. Anywho, make sure you check your oil to see if you got water in it. If you had water in you cylinder you probably got water in your oil. Either way I would change it.
hugemoth
Jul 20, 2020 03:28 AM
rcappie4
Jul 18, 2015 07:51 AM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
